Copper washer
Brian
06-13-2003 10:39:22
Just curious, but what is the reason for one copper washer on the upper waterpipe on John Deere two cylinders. I've got one with the gasket kit and am putting it on today but the tech manual doesn't give the reson for it.
Clooney
06-13-2003 17:59:04
 Re: Copper washer in reply to Brian, 06-13-2003 10:39:22
Brian, some use 2 or more copper washers. They are used on the bolts as water can seep up the BOLT threads & leak at the head area. The studs are turned in tight so they seal at the thread area & don't need those washers..If you use a good thread sealer you really don't need a copper washer(s)...
