JD 60 pistons
johnpb2003
06-12-2003 15:51:05
I have had the block of our 60 machined 90 over from standard now it seem I can't find a set of the reasonable priced 90 over pistons for a least the next thirty days. Anyone put me in the right direction any sooner? Thanks, John
SamH
06-14-2003 12:26:38
 Re: JD 60 pistons in reply to johnpb2003, 06-12-2003 15:51:05
I know its too late for this round, but if you do this again, buy the pistons first. They may vary a little from spec, so without them, the machine shop has no way of knowing what size to bore the cylinders to get the right clearance.
johnpb2003
06-14-2003 22:16:42
 Re: Re: JD 60 pistons in reply to SamH, 06-14-2003 12:26:38
Thanks for your reply, my problem was the machine shop did not know to what they would bore it out (45 degrees / 90 degrees / or 125 degrees)as one of the cylinders was very badly pitted and rusted.We were hoping for either of the first or second oversizes as we had advice the the cylinder walls are not that thick , so we wanted to stay away from the largest oversize. In Canada I can get 2, 90 over pistons, complete for 379.00 Canadian, or they would be close to 520.00 Canadian coming out of the States. So I guess I wait 30 days for the dealer to have them supplied to him. Thanks
Earl S.
06-12-2003 16:20:59
What do you think is a reasonable price for good quality American made pistons,pins,& rings???Earl In Illinois
