Installing new front tires on JD 110
Corey
06-12-2003 08:31:25
I got the new tires installed on my JD 110. What can I use to seal the rim and tire on the edge? The tires air up, but eventually the air leaks from the rim edge.
Thanks,
Corey
phil
06-12-2003 09:18:54
 Re: Installing new front tires on JD 110 in reply to Corey, 06-12-2003 08:31:25
Corey, I put tubes in my 1969 JD 110 - saves many weekend pump-ups when you were in a hurry to use the tactor. Also, you can run lower air pressure - easier on the sod & smoother ride. I put about 12 or 15 psi in mine.
Andy
06-12-2003 10:17:45
 Re: Re: Installing new front tires on JD 110 in reply to phil, 06-12-2003 09:18:54
I use Tire Slime or any of the other sealing compounds in the tire section. Works real well for me and it keeps any new punctures from ruining your day...
