JD-H BELT PULLEY BRAKE BRACKET
GERRY
06-11-2003 18:25:41
HOW DO YOU REMOVE THE BRACKET THAT HOLDES THE PULLEY BRAKE SHOE. I REMOVED THE COTTER PIN AND TRIED TO DRIVE THE PIN UP BUT IT WON'T MOVE AND I DON'T WANT TO BREAK IT.
Clooney
06-11-2003 18:43:54
 Re: JD-H BELT PULLEY BRAKE BRACKET in reply to GERRY , 06-11-2003 18:25:41
GERRY, after the cotter pin is removed the pivot pin should drive out. If it's frozen in there it won't come out easy & you could break the casting. ~If it's stuck you can try heat, if it still won't come loose you can try to work the 4 bolts out that hold the pivot cover on then heat the pin & casting & press the pin out.
~Worst case you will have to drill the pin out & install a new one...
Gary in Tx
06-11-2003 20:58:12
 Re: Re: JD-H BELT PULLEY BRAKE BRACKET in reply to Clooney , 06-11-2003 18:43:54
Hey Clooney,
Just wanted to offer an addition too your post. If you could take the 4 bolts out and remove the whole assembly you could soak the whole deal in some form of penetrating oil for a good long while. Heating and just trying to get it to barely move a little both ways is also good. Main point being to take time to do it slow and don't break that part.
