Combine 55
gaetan
06-11-2003 02:05:12
anyboby know how many hp for a gas 6 cylinder
john deer combine 55 thank you
ron in MN
06-11-2003 19:55:22
 Re: combine 55 in reply to gaetan, 06-11-2003 02:05:12
The Hercules QXD-3 has 64 HP as listed in the 55 Operator's Manual.
JD 4020 G
06-11-2003 16:16:07
The John Deere HE 217 G has 71 hp. The newer 55s have the 303. 80 hp.
David from Kansas
06-11-2003 08:45:59
Also depends on if it is an older 55 with the Hercules engine, or later with the JD engine. The later JD engine I would imagine had more HP.
David
GPULLER
06-11-2003 08:06:18
It depends on if it is gear drive or hydraulic drive. I belive I read in my 55 hydro manual that a hydro is 80 or 85hp and a gear drive is 10hp less. I can look it up and let you know.
Bill
06-11-2003 05:53:35
Im guessing about 63 flywheel hp,,,Bill
