2520 wiring harness
Colby
01-12-2004 16:52:07
Am restoring a 2520 powershift that someone took the trouble to put real oil pressure and amp gauges on. They also , as anyone would, cut and pasted wires liberally. I want to put it back with the "idiot lights" and need a wiring harness. It is a diesel under serial number 22000 and the harness number is AR38795. Does anyone know of someone who has parted one out? Or better yet does anyone have a new or used harness?
jared
01-12-2004 18:20:41
 Re: 2520 wiring harness in reply to Colby, 01-12-2004 16:52:07
i would sugest getting a new one from your local jd dealer, it may be expensive, but in the long run it will be well worth it. if you get a used one, it may have cracks in the insulation, showing bare wire, which could cause a short.
last year when i restored my 2510 i put in a new wiring harness. it came with a coule of breakers to protect the wiring harness. one went up by the alternator, and the other one went down by the starter.
jared
Colby
01-13-2004 04:53:12
 Re: Re: 2520 wiring harness in reply to jared, 01-12-2004 18:20:41
My dealer says he can't get one. I would be happy to get a new one if I could find one.
Jared
01-13-2004 20:02:38
 Re: Re: Re: 2520 wiring harness in reply to Colby, 01-13-2004 04:53:12
Try a different dealer. I bought mine at the dealer. A new wiring harness also adds a lot to the appearance.
Also try looking it up on the JD parts site. Jared.
