1944 Model A wont start
Dan
10-20-2003 10:16:34
tractor was running good then quit one day and will not start back in fact it wont even TRY to start! has good spark, fuel flow is good, plugs are sparking, what could it be?? its a handstart and ive tried to pull it off with no luck.
Bill
10-21-2003 07:00:26
 Re: 1944 Model A wont start in reply to Dan, 10-20-2003 10:16:34
of course your valves have to be working or you will not get any fuel into the engine, I have seen this problem on several A's and its always been early models 39 to 47 deere put that metal flange on the camshaft and its suppose to keep the bolts from working loose and falling out but if the bolts work loose they start to wobble and the bolts eventually strip out and fall into the oil pan im sure it may be the same on the early B's but i dont know. I always replace the bolts with a higher grade bolt and lock washers and they seem to work well. i think the metal flange deere put on the shaft was just to flimsy or maybe it was there lack of washers...not sure.
Dan
10-20-2003 15:16:02
thanks Bill took a quick look the cam shaft was loose and NO bolts thank you for the info. what makes them get loose and fall out?
Bill
10-20-2003 10:51:40
Remove your valve cover and turn the flywheel and see if your valves are working if not the next step is to remove the crankcase cover and take a look at your camshaft if its not broken check to see if the 4 or 5 bolts are still in the cam shaft that connect to the gear you will have to feel in there with your hand because its hard to see. Make sure the cam gear and crankshaft gear are lined up correctly you can take a flashlight and barely see the "V" marks on the gears, line those up and then replace your bolts use lock washers and bend the metal flange back over the bolts on the camshaft. i have had several model A tractors do the same thing and it was always the camshaft bolts so take a look and let me know what you find.
KB
10-20-2003 19:02:29
 Re: Re: 1944 Model A wont start in reply to Bill, 10-20-2003 10:51:40
Could that theory be extended to a Model B? I have a friend with a similar problem and will more than likely go over to see him next week to take and look at it with him. Sure would like to know if this is something I should look at.
Thanks
