JD 1050 clutch
Rickey
06-10-2003 13:34:40
I have a problem with my clutch being adjusted all the way out to the point my PTO clutch doesn't work. If I adust the clutch to where the PTO clutch works then the transmission clutch will not work. What will I have to do to correct? Will I need to put a new clutch in and is it a job for a tractor repair shop?
Thanks,
Rickey
johnd
08-27-2003 16:28:40
 Re: JD 1050 clutch in reply to Rickey, 06-10-2003 13:34:40
ricky, ihave the same problem with my clutch and pto on my jd 1050. i am interested in what you had to do thanks johnd
tommy thompson
01-27-2006 15:09:57
 Re: Re: JD 1050 clutch in reply to johnd, 08-27-2003 16:28:40
I need a clutch for my 1050 but JD wants 1500 dollars. Where can I but a after market? Thanks
