3020 leaky oil cooler
sawdust
06-10-2003 12:04:27
I have a leak in the oil cooler and I'm wondering how hard it is to remove, and if this cooler can be repaired or do I have to replace it.
david val
06-11-2003 01:11:21
 Re: 3020 leaky oil cooler in reply to sawdust, 06-10-2003 12:04:27
older ones can be repaired by a good radiator shop and need to be tested with 'high' pressure (100 psi and more).
newer aluminum ones also may be repaired by a shop that deals with aluminum.
the shop's pro will also tell you if repairable.
david
HOOSIER
06-10-2003 19:45:00
Had one repaired at a radiator shop but still leaked. Next option was visit Deere for new one. They have a update kit available.
jimks
06-10-2003 17:29:08
Most any radiator shop should be able to patch it.
