CLUTCH NOISE IN THE HOUSING
PAUL
06-10-2003 11:45:52
WHEN I DEPRESSED THE CLUTCH THE OTHER DAY IT STARTED MAKING A NOISE INSIDE THE HOUSING LIKE SOMETHING IS OUT OF ALIGNMENT OR SOMETHING BROKE, EVERYTHING SEEMS TO BE OK EXCEPT FOR THAT NOISE, ITS NOT AS BAD IF THE CLUTCH ISN'T DEPRESSED BUT THE MORE ITS ENGAGED THE LOUDER IT BECOMES, THE THROW OUT BEARING IS WORKING PROPERLY I CAN SEE IT THROUGH THE INSP HOLE ON THE SIDE, IF ANYONE HAS ANY IDEA WHAT MIGHT BE THE CULPRIT PLEASE HELP, I DON'T WANT TO TAKE IT APART. THANKS A WHOLE LOT.
PAUL
Wayne in Tn.
06-10-2003 12:59:23
 Re: CLUTCH NOISE IN THE HOUSING in reply to PAUL, 06-10-2003 11:45:52
Paul, since you don't say what model tractor you have, I am assuming it is a Dubuque John Deere. You mention seeing the throw out bearing through a hole. You can't tell the TOB is working correctly by just looking in the hole. First..Look in the hole to see if there is a grease zerk fitting on the TOB, if so, try greasing it to stop the noise.
Second.. if this does not stop it, you will have to break the tractor into.
Third...there are several things to cause noise in there. It could be no more than a bad TOB, or problems with the pressure plate, such as broken fingers, or the sleeve the TOB runs on could have come loose in the housing, causing it to come in contact with the pressure plate fingers. Let us know what model, live pto or not, to help determine a problem.
