JD 50 PS fluid question
Randy G.
06-09-2003 00:15:03
I have a JD 50. What oil do I use for the power steering? Also, My JD is a negitive ground and the amp meter works ok. Did somebody change something at one time? Its a 1955 model and I believe should be positive ground.
Clooney
06-09-2003 03:27:54
 Re: JD 50 PS fluid question in reply to Randy G., 06-09-2003 00:15:03
Randy, the correct P/S fluid is the Deere supplied P/S fluid for the 2-cylinder P/S systems.
~Last year I did a fairly involved test to try to find an alternative to that Deere high dollar P/S fluid & the closest I found was the Deere Hy-Guard. The Hy-Guard was the closest at the lower end of the temperature spectrum & 10W40 engine oil was closer at the higher end of the temperature range. So based on what I found the Deere high priced P/S oil is probably best if have a good tight non leaking system. Luckily it only takes about 5 quarts..
~On your ammeter, someone just reversed the wires on the ammeter posts to make it read correctly with a negative ground system. [that�s all it takes is a simple wire reversal to have it read either direction]�.
