3-pt. lift arm JD 430
Phil -- MO
01-12-2004 14:34:19
Lot's of hydraulic oil coming out of one of the lift arms on the 3-pt. hitch on my JD 430.
Can I just let the oil level stay below the arm?
How hard is this to disassemble and repair?
Do I need a special gear/arm puller?
With all the old equipment I got leaking hydraulic oil, I think I need to buy stock in an oil company.
Phil
cm
01-12-2004 19:32:03
 Re: 3-pt. lift arm JD 430 in reply to Phil -- MO, 01-12-2004 14:34:19
I've had pretty good success adding the Lucas power steering and hydraulic additive to my leaky hydraulic systems. you might want to try that
Dale in IN
01-12-2004 18:22:13
The 430s are notorious for leaking around the rock shaft. I put new seals in mine and it still leaked. That is why they call them little leakers.
J. T. Kilpatrick
09-09-2005 10:49:24
 Re: Re: 3-pt. lift arm JD 430 in reply to Dale in IN, 01-12-2004 18:22:13
I am in the initial stages of rebuilding my 430 and am looking for a replacement rock shaft. This is an obsolete item with John Deere and I tried doing a dealers search with no positive results.
Anyone know of a source that I might try?
