G powertrol gasket
Bill
06-07-2003 22:16:31
3 pt kept settling on my G, tore down to find gasket blown between cylinder housing and cover plate, when I install new gasket should I coat surfaces with some dressing or leave bare,,Thanks Bill
Clooney
06-08-2003 04:22:34
 Re: G powertrol gasket in reply to Bill, 06-07-2003 22:16:31
Bill, either leave it bare or use a hardening type gasket reinforcement compound. Hydraulic gaskets will migrate under pressure if a soft [remains soft] type gasket sealant is used. ~I personally use Loc-Tite 518 as it is a reinforcement as well as a sealer. Then wait a day or two before pressurizing the system. Also make sure you use a quality gasket & not a soft cheap piece of gasket material or you will do it again in a short while..
~Scuff the gasket surfaces up real good with a scotch pad [don't get any particles in the hydraulic system] & clean the metal gasket surfaces with brake clean or lacquer thinner before assembly...
Bill
06-08-2003 08:14:07
 Re: Re: G powertrol gasket in reply to Clooney , 06-08-2003 04:22:34
I will get some of that stuff, Thanks Bill
