John Deere 2030 Hydraulic System
A Markley
01-12-2004 13:13:53
Working on a 2030 and have a question about the hydraulic set up--specifically the outputs--
I have not encountered a similar set up as on this one (a single output with a three position control valve-works like forward, neutral reverse for reference)
I have several implements from another tractor with have a 2 hose set up--and I wondered how to change or modify this one to use them?
Thanks!
terry miller
01-12-2004 17:35:27
 Re: John Deere 2030 Hydraulic System in reply to A Markley, 01-12-2004 13:13:53
i have a 2030 from europe it has two lines on it i am new to restoring and working on it but i will take some pic of the setup so you can see how mine is done
david val
01-12-2004 14:49:23
the european models had 'spool type' scv in which a single outlet (with single spool) was an option. you can identify the spool by the round cup like cover on its back, usually with a small adjusting screw.
david
