Model 60
Keith
06-07-2003 08:52:59
I have a model 60 that has POWER BLOCK casted into the top of the engine block. Can anyone tell me what this means and if this tractor has more value than a regular 60
Mike F
06-07-2003 18:29:23
 Re: Model 60 in reply to Keith, 06-07-2003 08:52:59
You have a tractor supply company block made in the early to late 50's give or take, It will have 6" bore and really short pistons, your 60 used to have 5 1/2" bore, so you have .500 more bore than alot of other tractors, they were advertised to give 5 to 7 hp more than stock, I could be slightly off on that number, but that is what I remember, rings on the power block pistons are all above the pin due to the piston length, they run good and rings are sort of pricey. that is about all I remember on them, oh yeah, they made 3 blocks for that size of tractor, a 6-1 for early A's a 6-2 for A's up to 1949 and a 6-3 for late A's and the 60.
