4020 24v to 12
Larry806
06-06-2003 20:28:58
Neighbor has a 24v 4o2o. Starter has a short I have a couple extra starters from 404 combine motors I keep delco alt's around If I put the starter & alt on would it be easier to just build my own wireing harness or can I work with what's there? Thank you for replying Larry
Mike Aylward
06-07-2003 06:04:17
 Re: 4020 24v to 12 in reply to Larry806, 06-06-2003 20:28:58
Larry, you can use what you have with some minor modifications. Tie the A and B circuits together at the alternator and starter (brown and blue wires) and then install a starter relay above the starter to improve performance. You will have to reverse the generator bracket to mount the alternator and possibly grind out a little on it very small amount) to give clearance for the alternator fan. It is possible that you may need a different length fan belt. I prefer to use 2 6-volt batteries in series but you can use the 2 12's in parallel and install the 6's when the batteries next need replaced. It is not a hard job but takes some time. Your neighbor will be pleased with the conversion. Hope this helps. Mike
