JD-H BELT PULLEY BRAKE SHOE
GERRY
06-06-2003 16:05:30
AT A SHOW TODAY I SAW A CLIP-ON BELT PULLEY BRAKE THAT CLIIP-ON. WHERE CAN I GET ONE OF THESE FOR MY H.
lonnie
06-06-2003 19:41:50
 Re: JD-H BELT PULLEY BRAKE SHOE in reply to GERRY , 06-06-2003 16:05:30
Gerry Gerry Gerry..... ....Please don't put a clip on pulley brake pad on your H. That would be as tacky as a clip on tie on a guy taking a girl to the prom. The correct pad w/ rivets are super easy to put on (if I can do it anyone can) Call Sharpes or Lindstrom & they will send you what you need. Clip on brake pads are what you would expect to see on " The Fast & The Furious " BLLLUUUUHHHH!
Frank M.
06-07-2003 16:43:24
 Re: Re: JD-H BELT PULLEY BRAKE SHOE in reply to lonnie, 06-06-2003 19:41:50
I found a low buck replacement for my H. I had replaced the axle brakes, so I took one of the old linings and cut it down then drilled the holes for rivets. The curve is just about right to go on the belt pulley. All I had to buy is the rivets.
GERRY GEIER
06-07-2003 13:17:43
I THINK YOUR RIGHT I DON'T KNOW WHAT I WAS THINKING. I WILL CALL LINSTROMS'S
