JD 70 D (from April)
DAN
06-06-2003 11:06:11
This is an update from April when I was having trouble with the starter linkage on my 70 D. I removed the flywheel and rotated the starter ring. That did not work too well as the worn spot was too bad. Took the ring gear off again and flipped it over, after grinding the teeth to match the other side. I still had problems getting the linkage adjusted, took alot of trial and error. I did not take the pony motor off and remove the pony transmission. I think I could have seen what was causing the problem easier if I had. Thanks to the many posts addressing this problem the 70 D starts easily and is fun to run.
Thanks Clooney and Frank (F.I.T) for all the great info.
F-I-T
06-06-2003 12:40:00
 Re: JD 70 D (from April) in reply to DAN, 06-06-2003 11:06:11
Dan:
Good Deal !
It's such a difference when the pony operates smoothly. We used ours by pull starting for several years. After I tore it down and fixed things correctly, it will start any time.
Finally, it's depandable !
Frank
