4010 throttle
Steve
06-06-2003 05:52:27
Where is the adjustment for the throttle tension on the 4010, it will not stay open without holding it with your hand? Where is the choke butterfly? I cannot find it on the carb or close to the carb? Thanks, Steve
newgen
06-06-2003 20:14:44
 Re: 4010 throttle in reply to Steve, 06-06-2003 05:52:27
Just oprn the little door where the service cards are located and you'll find an adjusting bolt. I believe it takes a 7/16 socket w/ an extension. Be carefyl not to twist it off! Sometines the band on the adjustment is worn out, it really isn't that big a deal to replace. As for the choke butterfly, just follow the air cleaner hose to the carburator, it's right inside there. Hope this helps.
