38A transmission stuck
JR
01-12-2004 11:34:39
I recently acquired a 38A with a stuck engine. I am soaking it and have no reason to believe that I cannot free it up without much trouble. The problem that I have never seen before is I cannot move the shifter, hi-low or PTO levers. All three seem to be frozen solid. Any ideas on possible problem? Can I pull the top cover off without too many pieces flying out?? How difficult is it too get everything syncronized and back together? Is reassembly fairly intuitive or are there special instructions for putting it all back together? I don't know what to suspect for the problem, heck I have parts tractors that are full of water but still shift!
Clooney
01-12-2004 12:46:29
 Re: 38A transmission stuck in reply to JR, 01-12-2004 11:34:39
JR, it could be as simple as water in the trans that's frozen solid [a common problem].. If your tractor is in an area that's below freezing you might try putting a heater or salamander under the trans for a few hours & see if you can then shift it..
~If it isn't frozen water then you probably have a serious rust problem..
~You can easily remove the trans top shifter cover, nothing will pop or fall out.. To re-install just put all the shift rails in the center [neutral] then install the top cover with the shifter in the middle..
[email protected]
Tim...OK
01-12-2004 12:14:03
Not bad to get back together,pto lever is seperate,goes into case,just hi-low and shifter to line back up,go for it. nothing jumps out at ya,had the one of off my 38 yesterday.
Tim
