JD 46A Loader Troubles
NBC
01-12-2004 10:03:45
I have a JD 3020 Gas Syncro w/46A loader. The hydraulic lines are connected to both breakaway couplers located in the rear of the tractor. The control levers are located up on the dash next to the rockshaft control lever. When operating the loader up or down, the bucket begins to rotate open no matter what position the bucket is in. If the bucket is fully rotated closed (all the way up), it generally will not rotate on its own. But, definitely when the bucket is anywhere else from closed, it will automatically, on its own, rotate fully open when the up or down lever is operated. The outside lever rotates the bucket and the lever next to the rockshaft lever controls the up or down. Any suggestions?
thurlow
01-12-2004 11:41:51
 Re: JD 46A Loader Troubles in reply to NBC, 01-12-2004 10:03:45
Are you sure that you've got the hoses hooked up correctly??? Both loader hoses in one box and both bucket hoses in the other????? Not crossed up??? I've seen some weird things happen when these valves get worn..... ..
NBC
01-12-2004 11:50:13
 Re: Re: JD 46A Loader Troubles in reply to thurlow, 01-12-2004 11:41:51
Yes, the hoses are both connected to the correct box, in the same box.
chris
01-12-2004 12:47:09
 Re: Re: Re: JD 46A Loader Troubles in reply to NBC, 01-12-2004 11:50:13
Does the loader work good otherwise? Have you had this loader for awhile or just purchased it? It sounds like the cylinder packings or valves need work. With your bucket on the ground tie your outside/short lever in either position, does it lift the front of the tractor up, if not leave the lever tied and lightly touch the bucket cylinders with the back of your hand(that way if it is hot you'll pull your hand away instead of grabbing the cylinder and possibly burning yourself) a hot cylinder will tell you if the packings are bad. chris
NBC
01-13-2004 06:35:41
 Re: Re: Re: Re: JD 46A Loader Troubles in reply to chris, 01-12-2004 12:47:09
I just purchased this tractor in Aug '02. The loader does work well, except for problem I've indicated. If you set the bucket on the ground and rotate it, it will pick the front of the tractor off the ground. Do you think it is a valve sticking somewhere?
chris
01-13-2004 20:24:10
 Re: Re: Re: Re: Re: JD 46A Loader Troubles in reply to NBC, 01-13-2004 06:35:41
NBC, sounds like your valve needs some work. Just to see if it is the valve, shut your tractor off, move levers to release any pressure, and switch the hoses from box to box. Then see if your whole loader moves and your bucket stays put. The valve can be expensive to go through and will need the valve seats ground, the valves replaced, and then lapped in. Some independent shops might have the tools, if not take to a JD dealer, and have them check it with air when their done. chris
vern
01-12-2004 20:18:01
try swithing your hyd hoses around at the valve that their are plugged into. if your bucket "floats" the other way ,it could mean you have a bad hyd vavle.
