Jd 350 Crawler
Scott
06-04-2003 11:22:23
helping a friend with a JD 350 Crawler, machine runs fine and will move foreward ans bcakward just fine until you come to an incline or attempt to make a turn or attempt to use the front loader, then the machine will stop moving, the rpm of the motor will not change and continues to run fine, any help would be gratly appreciated.
Scott
jdemaris
06-04-2003 19:28:46
 Re: Jd 350 Crawler in reply to Scott, 06-04-2003 11:22:23
You didn't mention if it has a hydraulic reverser or a conventional clutch. If it has a reverser, does it not move in forward and reverse?
Scott
06-05-2003 06:48:09
 Re: Re: Jd 350 Crawler in reply to jdemaris, 06-04-2003 19:28:46
The 350 crawler does have a reverser, and it does move forward and backward, until you attempt to climb an incline or make a turn or lift the front loader then the machine will stop moving but will continue to run fine. The hydraulic presssure was tested at the valve body we had 120# in and out of the valve body and 90# to the cooler 25# out of cooler to the clutch.
