40 jd
Elton
01-12-2004 09:50:25
Does a 40 have a hydraulic filter? If so where is it? If not does it have some sort of screening system?
Wayne in Tn.
01-12-2004 10:33:14
 Re: 40 jd in reply to Elton, 01-12-2004 09:50:25
Elton, the 40 does not have any filters or screening system. The only way, is to open the drain on the left rear of the housing and drain and flush with kerosene or mineral spirits, and refill with 10w non- detergent motor oil, per Deere instructions.....
tom
01-12-2004 12:42:22
 Re: Re: 40 jd in reply to Wayne in Tn., 01-12-2004 10:33:14
Wayne,
i still think we should come-up with some type of filtering method for these dubuque TOM's ! since i only have one tractor, which one of yours would you like to experiment with - i can collaborate via the net, e-mail and digital pictures...lol
i think some time of filtering device on the return line close to the dash where there is a connection, out of the way but accessible and can be secured, is the place to try...
tom
Wayne in Tn.
01-12-2004 17:59:50
 Re: Re: Re: 40 jd in reply to tom, 01-12-2004 12:42:22
Tom, that is a good idea, but I am not too expierenced on the principals of hydraulics. I wonder if an in-line filter would cut down on the flow of oil to the pump? I have had good luck rebuilding the hyd. units, but not too good at inventing hydraulics.
tom
01-12-2004 19:29:07
 Re: Re: Re: Re: 40 jd in reply to Wayne in Tn., 01-12-2004 17:59:50
Wayne,
that was my only concern - any type of restriction to the pump, would that cause a problem? i guess i would need to know if the pump not only pushes oil to create pressure, but at the same time sucks from the return line...if so, what would be the maximum density of a screen or filter that would not prevent a bottleneck to the pump, but a screen/filter small enough to catch the debris going through the system to make it worth while and effective?
i do not recall of any type of filters or screens were used for any type of hydraulics in the early 1950's, but the principles still are the same...i guess the real question is can we create something that is viable with the technology of the 50's? it would be interesting to discern what year was the 1st year that JD or another tractor company starting using filters or some type of screening system...they had crankcase filters for the oil, why not the hydraulics? i will post the question and see if anyone knows.
tom
Dave M. 56 JD40
01-12-2004 20:14:25
 Re: Re: Re: Re: Re: 40 jd in reply to tom, 01-12-2004 19:29:07
I'm no hydraulic expert, but the problem you may run into is if the restriction on the line is too much and it begins to pull a vacuum, the pump can cavitate and eventually fail. You may be able to get away from this if you had a good supply of excess oil (supplemental reservoir) and the return/pump feed system would probably have to utilize a large screen area (to reduce the possibility of plugging and, eventually, cavitation) and be well vented.
Good luck,
Dave
tom
01-14-2004 03:59:28
 Re: Re: Re: Re: Re: Re: 40 jd in reply to Dave M. 56 JD40, 01-12-2004 20:14:25
Dave,
You might be right...seems like a lot of work for potentially a small payoff...maybe when i retire in 20+ yrs i can spend some more time on this...just need to keep changing the fluid in these TOM units...thx, tom
