3020-2755 3point lift capacity
HA in Oh
06-04-2003 08:12:54
With all the soagy weather we have been having,I decided to get a bale wraper and make some haylage. The wraper is a 3 point and weights 1200lbs and with a 5ft wide bale 4ft in dia the 3020 didn't won't to lift them. Is there a way to raise the lift capacity on early model 3020? I also have a 2755, would it lift more then the 3020? Thanks for all help.
Brokenwrench
06-04-2003 09:37:33
 Re: 3020-2755 3point lift capacity in reply to HA in Oh, 06-04-2003 08:12:54
There is no easy way to increase lift capacity of either tractor. You could fabricate brakets, cylinder mounts etc. but then the rest of tractor has neither the structural strength or the ability to be manuvered with 3500-4000+ lbs. hanging on the 3pt, not to mention all the added stress of the bale spinning around. You would probably have to add 1000-1250 lbs to the front end of either one just to keep them down when using the wrapper,not to mention trying to move around with that much weight hanging on the back.
