H Reduction Gear cover question
Gary in TX
06-03-2003 13:31:03
Hey guys,
The 41 model H I'm working on is coming along at a snails pace with everything else thats going on in my life right now. I need to know something at the stage I'm at now however. I have the belt pulley off and looks like all the bolts are out of the cover, including the one behind the clutch/pulley brake bearing. It seems still pretty locked on there, is there anything else that has to be taken loose for the cover to come off?
Thanks!
dan_41jdh
06-03-2003 15:05:40
 Re: H Reduction Gear cover question in reply to Gary in TX, 06-03-2003 13:31:03
Gary, there are nine exposed capscrews, and one "hidden" capscrew that resides just inside the clutch fork opening, for a total of ten bolts, that retain the reduction cover to the transmission housing on your H. If you've removed all ten, it should come off. However, sometimes those old gaskets can be kind of sticky.
Gary in TX
06-03-2003 15:12:19
 Re: Re: H Reduction Gear cover question in reply to dan_41jdh, 06-03-2003 15:05:40
Thanks Dan,
I think they are all out, I have not tried to pry on it or anything as I know what that could do if you forgot to take one out. An uncle of mine had to go to the wrecking yard and get a new bell housing for his truck because of that oversight.
