430 steering problems
spurcrazy
06-03-2003 13:17:54
I have a 430 john deere tractor and ever since my family has owned it it never has steere smoothly .
It acts like it it catching in the gearbox. any help would be greatly appreciated. thanks spurcrazy
Henry J
06-03-2003 14:41:19
 Re: 430 steering problems in reply to spurcrazy, 06-03-2003 13:17:54
Spur
We don't knw what model you got or if you have power steering but here is my thoughts. If you havn't pulled the sheet metal and checked the lube in the box or boxes in the front pedistal that is the starting place. The 90 degree box on top of the pedistal usually leaks dry through the years. Pull the top off it and peek inside and hopefully you will find something like lube and not metal flakes from a ground down worm gear. I don't know about non power steering, but ps has an additional gear box that has to be filled with lube where the rack and pinion is. If you have to rebuild the top gear box go with JD corn head grease for lube - it is designed to not seep out likely places such as the old vertical shaft. Also the top gear box should have a lash adjustment for the worm gear similar to the old car steering gear boxes.
