Blowing smoke
Gary
06-03-2003 08:21:14
We have a john deere garden tractor w/ a koler
engine runs fine but is blowing alot of smoke
but i can not fine any reason for it????
tom
06-03-2003 12:02:09
 Re: blowing smoke in reply to Gary, 06-03-2003 08:21:14
Did you happen to accidently put some 2-cycle mixure gas in gas tank? You may also be burning excess oil if a valve is bad and it is burning oil. Those are the only two possibilities, except spraying something in the carb. to clean it, but that only lasts a couple of sec's...
Gary
06-04-2003 04:21:02
 Re: Re: blowing smoke in reply to tom, 06-03-2003 12:02:09
NO fresh gas was put in valves were check head was cleaned could it be a blocked oil beather???/
Lee
06-04-2003 05:43:30
 Re: Re: Re: blowing smoke in reply to Gary, 06-04-2003 04:21:02
Head was cleaned? You had it off? That could be it as its hard to get all the little carbon chunks out of the cylinder when the head gets pulled. Black smoke could be from plugged air cleaner, but blue smoke because of a plugged oil breather would be a new on me. Pull the line loose if you can while running. If you need to clean your glasses after doing this, you've got too much blowby and that means its ring job time.
