JD A Magneto.
Brad
06-03-2003 02:49:14
I have a magneto problem that I have never herd of happening to anyone else. The shaft has broken off flush with the armature inside the magneto. I do not see any reason for this to happen, but it did. Now for the question. I have a magneto for a JD "B", the model number is the same, but the spec # is different. Can I use this magneto in my "A"? And where is a good place to get my old magneto repaired or replaced? Thanks for the help!!!
Johan
06-03-2003 07:00:18
 Re: JD A Magneto. in reply to Brad, 06-03-2003 02:49:14
I had the same happening on model D with Wico X magneto. Was going down hill when it snapped. Never found out why. Bought a new magnet rotor from Roberts at more than $70.
Clooney
06-03-2003 03:52:28
Brad, as long as the impulse lug length is the same it should work. You might have a slightly different running advance but it won't be far enough off to effect it very much..
~If you tell us the mag make & model [& any numbers on the impulse cup] we can give you a little more specific information...
