HELP.....2 CYL GAS MAGNETO ALIGNMENT
JD MIKE
10-20-2003 09:27:30
I have a 2 Cyl JOHN DEERE gas engine out of an old combine...don't know the size.....its on a drilling rig and my dad took the whole mag out and now i don't know how to line the gears back up....it does have a little flapper over the flywheel housing....when u rotate the flywheel u can see the word "spark" on the flywheel itself.....do i use this and set the piston at TOP DEAD CENTER?.....PLEASE HELP AS WE ARE GOING TO DRILL NEXT WEEK
Bob
10-20-2003 10:15:13
 Re: HELP.....2 CYL GAS MAGNETO ALIGNMENT in reply to JD MIKE, 10-20-2003 09:27:30
When #1 cylinder (the one nearest the radiator)comes up on compression stroke, the mag should "snap" at the mark labeled "spark", and the rotor in the mag should be lined up with the terminal connected to #1 cylinder. As you crank the engine, 180 degrees later, the #2 cylinder will "fire".
This prabably is an "LUC" engine?
JD MIKE
10-20-2003 10:58:32
 Re: Re: HELP.....2 CYL GAS MAGNETO ALIGNMENT in reply to Bob, 10-20-2003 10:15:13
SO TDC ON #1 I SHOULD HERE A SNAP....POINTS CLOSING?.....AND MARK ON FLYWHEEL LINED UP WITH SPARK LETTERING.....CORRECT?.....IS THERE TIMING DOTS ON THE FRONT GEAR FOR GEAR ALIGNMENT?
Bob
10-20-2003 13:18:46
 Re: Re: Re: HELP.....2 CYL GAS MAGNETO ALIGNMENT in reply to JD MIKE, 10-20-2003 10:58:32
As you rotate the engine, and approach the "spark" mark for #1 cylinder, the impulse on the mag should snap. The points will be closed, and open at the second the impulse snaps. I am unsure of the gear marks. I have one of those little engines. It runs like a charm, and I haven't had to work on the mag for 20 years, so offhand, I can't answer the question about the marks on the gears.
However, you do not need to worry about the timing marks on the gears. Just try to get the mag in the approximate position, rotate the engine over and see where it fires in relation to the "spark" mark. If it is off one way or the other, reomve the mag, rotate it a tooth or two in the appropriate direction, and try again, until you get it to fire at the "spark" mark.
It is good practice to remove the wires from the spark plugs, and ground them away from the spark plugs until you are CERTAIN the mag is firing at the "spark" mark, and no earlier. As I'm sure you are aware, even though this is a small engine, it can still deliver a a nasty "kick" to the starting crank, if timed too early.
