49 B Headgasket Sealer
JB
01-12-2004 06:07:08
Should I put the sealer just around the outer perimeter of the gasket, or on all of the gasket surface? Thanks for your help. JB
Clooney
01-12-2004 13:14:59
 Re: 49 B Headgasket Sealer in reply to JB, 01-12-2004 06:07:08
JB, you can do it either way, personally I put a [very light] coat of #3 Permatex on both sides of the head gasket [not on the fire rings around the cylinders]. Then torque from the center out in a criss-cross pattern.. Remember using any sealer on the head gasket does require a re-torque after it is run through a few heating & cooling cycles.. Never had one leak yet [at least that I know of]...
[email protected]
John T
01-12-2004 07:00:18
JB, Been selling a lot of that weld laterly?? Ive had good luck with Kopper Kote, but I dont use it on the gaskets metal ring portion around the rim of the cylinders, trying more to seal the coolant areas. Have the head clean and dry n smooth and I snug down the head bolts then torque in 5 to 10 lb increments slowly each time in sequence to spec, then after a good warm up, retorque once more. Works for me anyhow, others probably use different methods or have differing opinions.
Best Wishes
John T
