Hydraulic fluid screen
Nick in KY
06-02-2003 09:17:14
Hydraulics fail at low rpm. 1966 JD 3020 diesel with syncrorange. Was told it could be clogged screen accessed by some plug near the hydraulic filter. Anybody no about this screen. Couldnt find it in manual. Already changed the filter.
Brokenwrench
06-02-2003 10:29:24
 Re: hydraulic fluid screen in reply to Nick in KY, 06-02-2003 09:17:14
You can clean the screen, but I think it is more likely that you have an internal leak in one of the hydraulic functions. This bleeds off pressure at low rpm�s causing loss of hydraulics.
twopop
06-02-2003 09:29:18
the screen is located to the rear of the hydraulic filter,under a plug that is about 2 inches in diameter,and just ahead of the rear axle housing.when you pull the screen,you will also get about ten gallons of oil.
Nick in KY
06-02-2003 09:42:21
 Re: Re: hydraulic fluid screen in reply to twopop, 06-02-2003 09:29:18
Thankyou, I saw the plug with a sqaure head behing the filter and a cylinder shape to the housing behind the plug.
