JOHN DEERE 2020 GAS
DICK WEST POINT
06-01-2003 18:24:00
Just bought a JD 2020 gas tractor seems to have antifreeze in the oil. any sugestions on what to look for? Does it have wet or dry piston sleeves?Thanks Dick....
GK
06-01-2003 20:34:30
 Re: JOHN DEERE 2020 GAS in reply to DICK WEST POINT, 06-01-2003 18:24:00
About eight years ago when my 2020 had the same problem I fixed it with new o-rings around the sleaves.It only had about 1500 hours at the time so I did not put in new sleaves.I suppose it could be a head problem too but I think they have a pretty good head on that engine.I think JD came out with a different sleave with new o-ring placement for that engine.Do you suppose if you would take the pan off and then pump the cooling system up to pressure it would show you if it was leaking around the sleaves? If nothing there maybe a head gasket or head problem.
Dick West Point
06-03-2003 18:15:35
 Re: Re: JOHN DEERE 2020 GAS in reply to GK, 06-01-2003 20:34:30
GK, Thanks for the reply,sounds like thats what I'll do. This is going to be a winter project we have four ahead of it to restore...Thanks again. Dick from West Point IND.
