Breaker point wire on K241
Corey
06-01-2003 14:40:01
Where do I attatch the breaker point wire on my K241?
Donny-B
06-01-2003 14:45:10
 Re: breaker point wire on K241 in reply to Corey, 06-01-2003 14:40:01
It attaches to the negative side of the coil along with the condenser.
Corey
06-01-2003 18:17:03
 Re: Re: breaker point wire on K241 in reply to Donny-B, 06-01-2003 14:45:10
where does the condenser go to and from?
Donny-B
06-02-2003 14:24:31
 Re: Re: Re: breaker point wire on K241 in reply to Corey, 06-01-2003 18:17:03
Corey, The condensor bolts on to the blower housing with the coil.(Use one of the coil bolts) The condensor wire goes to the negative post on the coil along with the point wire. The hot wire from the switch goes to the positive post on the coil. Hope this helps.
