JD R starter
Mike
06-01-2003 10:37:21
Is there any way to convert an R to electric start? My neighbor has one that has a bad cam on the pony motor and was asking if it could be converted to electric start. thanks for any info
Bob
06-02-2003 11:18:23
 Re: JD R starter in reply to Mike, 06-01-2003 10:37:21
Email me with part number off of old cam. Have a good used one REASONABLE, if it's what you need.
G Taylor
06-01-2003 19:33:26
Re-grinding cams is one of the cheapest and easiest repairs to do when any engine is rebuilt. Worn cams are one of the major causes of engines that "just never work right". Just take the offending cam to the local engine rebuilding machine shop.
Paul
06-01-2003 11:29:18
there is a guy in wyoming (I think) that put a cat starter (24 volt?????)on an R using angle iron.the angles were bolted to case with pony mont bolt holes it was pretty crude but works.I think a thick flat plate would be neater. one problem is though is that stock piston R starts harder than an 830( doesn't turn harder just doesnt fire as easily) so good batteries ( at least two maybe four) wil be required. I am quite sure the parts you need for the pony could be located.Paul
Dave in Ohio
06-01-2003 14:24:53
 Re: Re: JD R starter in reply to Paul, 06-01-2003 11:29:18
Paul has good advise. Repair the starter. Will be a bit pricey but a much better job.
Mike
06-01-2003 14:30:40
 Re: Re: Re: JD R starter in reply to Dave in Ohio, 06-01-2003 14:24:53
Where can I find a new cam for it? (the starter)
old fashioned farmer
06-01-2003 17:21:02
 Re: Re: Re: Re: JD R starter in reply to Mike, 06-01-2003 14:30:40
Give the local John Deere dealer a call. There might be something sittin around in a dealership somewhere. Ask 'em to do a search for ya. I found a gasket for mine that my local dealer said didn't exist anymore. Went to another dealer, had him search, found one in iowa. If that doesn't turn up look up twocylinderdiesel.com and check some of his links to R parts places. Good luck and God bless.
-old fashioned farmer
