JD B All Fuel Selector Valve
Bill
06-01-2003 05:55:29
The B has been setting for a while and the selector valve won't turn? I believe these were supposed to have stops when they were in a front or back tank position. The stops did not work and I had to fiddle with the valve to find a spot where the gas would run. Is there a rebuild kit for this valve or should I look for a new one?
phil
06-01-2003 10:36:42
 Re: JD B All Fuel Selector Valve in reply to Bill, 06-01-2003 05:55:29
Bill, there are no 'stops' in the valve, it should rotate all the way around. There is a tapered brass cone, about 2 inches long, that rotates inside a tapered hole in the valve body. The seal under the large nut provides a 'load' so that there is friction between the cone & the hole. You tighten the nut until you get 'drag' when you turn the valve handle. Probably all you need is a seal, JD has them for about $2.
Mark
06-01-2003 06:52:46
All that is in that valve is a gasket behind the nut. It is available from JD. you may have to apply heat and allow the valve to cool to disassable it.
