D SPARK PLUGS
MDM
05-31-2003 21:01:05
need suggestions for the right heat range plug for a 1936 D. tractor will do limited heavy work, mostly just pleasure rides.
Bob-Wyo
06-01-2003 19:52:18
 Re: D SPARK PLUGS in reply to MDM, 05-31-2003 21:01:05
MDM I run Autolite 3077 is my 31 up D's and have great luck with them, not so good with Autolite 3076 or AC's tho, seems if you flood it once the plug smokes up and will not fire, sure not a problem with the 3077's. The 3077 is a hotter plug but best of all it is a deep reach one. NAPA gets them by the box for me.
Bob
Marty Z
06-02-2003 17:05:17
 Re: Re: D SPARK PLUGS in reply to Bob-Wyo, 06-01-2003 19:52:18
YOU ARE RIGHT IT WAS AUTOLITE.. but you knew what I wanted to tell him . thanks Marty
Marty Z
06-01-2003 06:45:42
I was told to stay away from champion. I have had real good luck with AC 3076 but they do foul after a while if not run real hot. I have just found a couple of AC 3077 and I was told that they run hotter and stay clean longer..
Marty
Dan
05-31-2003 22:47:28
D16 Champion
