Heisler Head?
James D
01-11-2004 20:20:16
I have run across a Heisler head that I am told will fit my 1937 B. I have heard the tractor puller talk of these, but never really knew what one was. Are the ports and valve sizes the same as my B now, or are they larger? Also, can someone tell me about how much the compression is raised and will I still be able to crank it by hand. Do they actually help the power? I'd like a little help pulling my 2 bottom plow, but hate to change a lot.
2 Cylinder
01-12-2004 07:18:38
 Re: Heisler Head? in reply to James D, 01-11-2004 20:20:16
It all depends on the type of pistons you have. If you have the all fuel pistons you won't have any problems. But if you are using aluminum high compression pistons you may encounter some spark knocking. It will increase your power, not sure how much on a JD-B, but on the JD-G it increased the power by 10hp.
DickW
01-11-2004 20:48:24
They are probably for the belt pulley dust shield.
DickW
01-11-2004 20:51:00
 Re: Re: Heisler Head? in reply to DickW, 01-11-2004 20:48:24
Disregard the previos post - I kinda missed by about two postings. Sorry about that.
