JD-G
frank
05-31-2003 16:13:18
I have aJD-G year 1949, has a 1-3/4 pto shaft, all i have seen were 1-3/8, can you tell me what was this used for, it has 540 splines,thanks
Dan
06-01-2003 10:06:41
 Re: JD-G in reply to frank, 05-31-2003 16:13:18
I have a 1938 G also with the 1 3/4 inch pto shaft. Purchased an adaptor years ago when they weren't quite so expensive. Only thing is if you pull a baler or something where you have to worry about the standard length from end of pto to drawbar hole, you have to add a plate to the drawbar to extend it out due to length of the adapter. I had a number 5 mower for the G and pto shaft end for the 1 3/4 shaft. Would swap the the regular end and eliminated the need for the adapter.
Clooney
05-31-2003 16:47:51
Frank, the "G" had a lot of PTO horsepower so Deere put a bigger PTO shaft in it. That was before there was an industry standard for PTO shaft spline size so there was a variety of sizes offered on different tractors.
~After early 1950 the "G" came with a 1-3/8" PTO shaft spline size.
~You can probably install a later shaft or use a 1-3/4" to 1-3/8" adapter.
Ron Stephens
05-31-2003 18:44:20
 Re: Re: JD-G in reply to Clooney , 05-31-2003 16:47:51
You can not change just the shaft. The PTO gear and pinion have to be changed also. Best bet it to use an adaptor.
Bayou Dave
06-01-2003 08:50:47
 Re: Re: Re: JD-G in reply to Ron Stephens, 05-31-2003 18:44:20
Tisco carries that pto adaptor. Costs around $84.00 if I recall.
John T
05-31-2003 18:48:26
For sure, and I have one of the adaptors, I found it when I was cleanign the shop just last week, hadnt seen it for years since I purchased it from Shorty Dear recently deceased. John T
