Wide front swap out for narrow front on 720
anothertractor
05-31-2003 03:27:40
I am in the process of taking a square wide front off of a 720 row crop and replacing it with a roll-o-matic. I have all of the wide front removed except for the piece that bolts to the tractor that allows the alxe to pivot, I have removed the 4 bolts from the bottom side that I can see and it won't come off. Does anyone know if there are some bolts that come in from the top side as well?
Thanks
anothertractor
05-31-2003 10:07:06
 Re: wide front swap out for narrow front on 720 in reply to anothertractor, 05-31-2003 03:27:40
Thanks for the replies. I will go see if that will work now.
F-I-T
05-31-2003 05:20:08
third party image
I checked in the parts catalog, and all I can suggest is that there are two dowel pins that might be hanging up in their bores.
Frank-in-Tallahassee
70D // 855
Mark
05-31-2003 05:17:24
There are two dowel pins that are probably stuck thus still holding pivot bracket to tractor.
