Carb settings
60 guy
05-29-2003 15:25:16
Does anyone know the idle and load screw settings for a john deere 60?
60 guy
06-01-2003 09:52:01
 Re: carb settings in reply to 60 guy, 05-29-2003 15:25:16
hey, its a duplex dltx -81. I have another question, is the load screw under the bowl? Is there only one idle adjustment screw? I thought that the two screws under each throat body were the air/mixture screws? I'm getting a little confused... Thanks for the help guys.
John T
05-29-2003 17:16:03
Hey Guy, If you mean a duplex (2 barrell) carb, the main load adjustment in the bottom center on mine was in all the way, then back out about 2 1/2 turns for starters, and then under load I open them till she black smokes, then screw them back in slightly just till she stops. When I set my idle adjustments, I first remove the plug wire on the side I'm NOT setting, and then at slow idle (runnin on just that 1 cylinder) screw the runnign side in till she starts to lean and cut out, then back out about 1/2 turn. On a single barrell carb, I start with the load needle out about 3/4 to 1 turn and the idle needle out about 1 3/4 to 2 turns, and tweak them from there under load and idle to best performance.
John T Nordhoff
Clooney
05-29-2003 15:50:28
60 guy, sure we can help but will have to know if it has the single or dual induction carburetor?
Mike F
05-30-2003 19:05:53
 Re: Re: carb settings in reply to Clooney , 05-29-2003 15:50:28
I dont think a 60 ever had a single induction carb, if they did make one, it would be very rare, clooney, others ?
Clooney
05-31-2003 08:59:03
 Re: Re: Re: carb settings in reply to Mike F, 05-30-2003 19:05:53
third party image
Mike, not many....
