JD 60 put in gear and nothing happens
Dave
01-11-2004 18:19:32
i have a 60 and i have noticed once and awhile that you could put it in 4th and push in the clutch and nothing.Move the shifter around and put it back in and it would go.???now it doing the same and more often in other gears. is this from worn shifting forks? thanx Dave
Clooney
01-12-2004 03:16:35
 Re: JD 60 put in gear and nothing happens in reply to Dave, 01-11-2004 18:19:32
Dave, now that your problem is happening in more than one gear probably tells us you have a problem with the under/over drive shifter part of the trans [A common problem area]..
~Try to be more deliberate as you come through the crossover gate when you shift & see if your problem gets better.
~Does the shift lever stay put when the trans doesn't pull? Or does the lever move out of the detent slot?.. If the lever stays put your problem is more than likely an under/over drive problem..
~If your problem is in the under/over drive gear set the usual cause is worn trans bearings or a worn input shaft bearing, but worn shifter parts can also contribute.. See if there is a lot of lateral play in the upper trans shaft?
~About all you can do is remove the trans top cover & inspect for worn trans shaft bearings, a loose & worn shifter, & possibly re-adjust the shift shafts for proper centering & a clean neutral.. It probably wouldn�t be a bad idea to inspect the input shaft outer bearing [small cover on the 1st reduction cover] to see if it�s loose or worn..
[email protected]
Dave
01-13-2004 19:55:26
 Re: Re: JD 60 put in gear and nothing happens in reply to Clooney , 01-12-2004 03:16:35
thanx for all the info, i really appreciate you taking the time to writing back. thanx again Dave
Ron
01-11-2004 19:11:59
Something is definitely worn in there, and you had better check it out before you tear out more gears than the tractor is worth..!!! Could be anything from excessive end play in shafts, worn shifter ball, detents and springs... Even a bent fork, or bent shift lever... Clooney is the Expert, but I know ya better get in there and find out what is wrong...!!
Ron.
Loren - Minnesora
01-11-2004 19:47:31
 Re: Re: JD 60 put in gear and nothing happens in reply to Ron, 01-11-2004 19:11:59
You diffently have some wear there. However, before I restored my 60, we used it for years (I MEAN years) like that. Dad's A was the same way. You are going around the 2 shift patterns (right and left, above 2nd) to fast and losing the fork there. When going to R, 1st, 4th, drop the lever down toward 2nd before going up. Same on the other side, drop down to 5th, before going to 6th or 3rd. My 50 and B were the same way after heavy farm use. Did the same thing, Make sure you hit the corners before going from one side to the other.
ron in MN
01-12-2004 10:05:03
 Re: Re: Re: JD 60 put in gear and nothing happens in reply to Loren - Minnesora, 01-11-2004 19:47:31
Loren - Noticed over on page 2 that you are in southern MN. I'm near Waseca. Wonder where you're located.
Loren - Minnesota
01-12-2004 12:20:33
 Re: Re: Re: Re: JD 60 put in gear and nothing happ in reply to ron in MN, 01-12-2004 10:05:03
Ron,
I usually say Mankato, but closer to Madison Lake. Grew up 12 miles SW of Waseca. Wife is from Waseca. Worked in Waseca a number of years before the wife was transfered to Mankato. Also lived in Owatonna for a while.
Loren Flemming
[email protected]
