730 PTO oil type and qty
730 DMAN
05-28-2003 13:17:34
What qty and type of oil is used in a 1959 730d pto system compartmant.
Thanks
MIKE HANLEY
05-29-2003 05:31:57
 Re: 730 PTO oil type and qty in reply to 730 DMAN, 05-28-2003 13:17:34
We use brand FARM OYL #30 GP3 in everything. The engines of the 430 crawler, 630 and the 730 Diesels and the PTO's and the Hyds plus the old CJ-2 JEEP. That way we only have to have one oil plus the John Deere power steering oil. Been using it for over 30 years.
WJw
05-29-2003 02:30:54
The jack idea sounds like a good idea.
We took a piece of pipe that fit neatly over the axle and would contact only on the wedge and welded a pad on the end to beat on. Now loosen what you need to, maybe a little heat, a couple 12 lb sledge smacks and she should be free. this worked on some wheels that havev't been moved in 20+ years
good luck
JD 4020 G
05-28-2003 16:47:27
I use Hy-gard in the PTO clutch of my 620.
Capcity of housing is approximately 4 U.S. quarts. The oil level should be up to the bottom of oil level check plug. BTW at the time your tractor was new, they used SAE 10W oil. Hy-gard is made for wet clutches, and will work good.
