Hydraulics,Need help Mike!
Don
05-28-2003 05:30:00
When you worked on the 310 for A friend,did you remove the engine first to get at the clutch & TRANS PUMP?Getting ready to tear into it.Any pointers would be greatly appreciated,Don
Mike
05-28-2003 09:35:54
 Re: Hydraulics,Need help Mike! in reply to Don, 05-28-2003 05:30:00
Split the tractor at the bellhousing to engine. Raise the loader and block up securely with angle iron on both rams.Install some wedges between the axle and tractor frame so it won�t rock. Support the rear of the tractor on the loader frame, remove the tach. cable,hydraulic lines, wiring,throttle linkage etc.Drain the coolant down about 1 1/2gallon,remove the water temp guage from the rear of the head. A good floor jack with a block of wood on it will support the front end during splitting. Roll the engine away from the rest of the tractor. The clutch is on the flywheel, the trans. pump is inside the bell housing with a ring of bolts around it, part of the reverser will come out with it. Check the sealing rings, and clutches on it while it is out.
Don
05-29-2003 19:05:13
 Re: Re: Hydraulics,Need help Mike! in reply to Mike, 05-28-2003 09:35:54
Thanks Mike! You have been very helpful.Wish it was inside but this one died in the yard right side of the house.Should be intresting.May be getting in touch with you again.Thanks again for your help,
Don.
