JD 1010..any good?
Tim
05-28-2003 03:09:19
Looking for an all around tractor. Found a 1010 gas relatively close to me for sale. Any pros/cons on this tractor?
Did it have Live PTO? I have been told it does, but can't see where that was even an option on that tractor.
Size good for a 6' mower?
Loren
05-28-2003 10:45:21
 Re: JD 1010..any good? in reply to Tim, 05-28-2003 03:09:19
I have a 1010 and use it to pull a 5' mower. I think it would pull a 6' one but would have to pull in a pretty low gear. I pull the 5' mower in third gear. In thin stuff I have used fourth and in heavy it has to be second gear. Mine does have live PTO so I just figured they all did. But there are some negatives. The hydraulics are pretty different from most other J-D's and my dealer refuses to even work on 1010 hydraulics. 1010's are not numerous so parts are harder to find. I had to go to the dealer for brake discs because none of the after-market people had anything that would fit. The brake locks are a pain. Mine has adjustable rear wheel hubs rather than spin-out wheels. I still haven't been able to get the bolts loose in the hubs, but fortunately it doesn't matter that I can't adjust the rear wheels. Biggest drawback it seems to me is that they don't show a lot of power at low rpm's. Some have power steering on them (mine does not) and I wonder how well that works given the power limitations of the tractor.
M Young
05-28-2003 08:56:26
I think they are a decent tractor, they had a bad reputation because of the sleeve deck and finicky hydraulics, But there are several people who really like them, and if it was well cared for that makes a world of difference. It depends on the price and shape weather it would be a good investment. As far as the brush hog, my 2010 pulls a 6'mower and will bog down on tall wet grasses. good luck
rob-o
05-28-2003 07:11:28
I just picked up a 1010. Once I get the radiator fixed, and the carb. it will be great. I plan on putting a 5' mower on mine. I don't know about a 6'. Good Luck trying to get help on this board, with a 1010. They either don't like this model, or don't know anything about it. I have better luck on other boards.
Gary
05-28-2003 07:34:18
 Re: Re: JD 1010..any good? in reply to rob-o, 05-28-2003 07:11:28
I have a 1010 RUS. It will not handle a 6 ft. mower in very tall weeds/grass. I use a 5 ft. and that lugs it down quite a bit. Live PTO is an option but mine dont have it. Lots of problems with the clutch and hydraulics too. What other boards do you use for help with your 1010?
J.P.
05-28-2003 08:53:36
 Re: Re: Re: JD 1010..any good? in reply to Gary, 05-28-2003 07:34:18
Gary,
It sounds like you have the same 1010 I had 15 years ago.
