720 Gas and D, R R Thermostat
Gerry
05-27-2003 14:50:48
I have a 1958 720 gas and diesel ( pony ). I am plannig to open it up to put the thermostats back in. They don't reach 140 after running them for over an hour. They just heat up enough to get off the peg. Reading the owners and IT manuals I still have some reservations. I have done this on a 50 and never did get the broken bolts out of the block removing the cylinder water outlet pipe. Had to redrill and tap the holes. Not fun.
Question.. Can I put the thermostat in without 1. removing the radiator grille? 2. Can I put the thermostat in without removing the cylinder water outlet pipe from the block? This could be tight. There is a what I call a spacer housing between the thermostat housing and the radiator. Will this open it up enough to give the space required?
Looking to do both tractors. Thanks in advance... Gerry
