As many of you know, I recently acquired a 1947 B that I've been bugging everybody with questions about.I plan to restore this someday, but I'd like to get it running first. Being basically impatient, and not willing to wait for the gas tank on my new '47 B to be reconditioned, I rigged up a temporary gas tank from a plastic oil jug to my newly rebuilt carb. I hooked up a hotwire to the coil (the wiring needs to be redone) and hit the starter. After giving it some choke, it started poppin'! At first, when it was running, there was a nasty sounding howl that sounded like something scraping. I shut it donw and investigated. I never found what it was, but after a few times starting, it vanished. I think it was something stuck in the clutch. It was blowing smoke out of the bottom, and I thought that it must have an exhaust leak or something. Well, once I looked under there while it was running, I realized that the compression relief valves were open. Doh! I didn't even realize these newer B models with electric start had these valves. I guess they are there for when the battery is too weak to turn it over under full compression. So after closing the valves and tweaking the needle valves, the engine runs very, very well. No hint of smoke. After it is warmed up, I can bring the idle down to something like 100 rpm or less- just absurdly slow. VERY COOL. It is so fascinating to have the engine running so slowly that you can mentally picture the pistons going up and down. I heard that at low rpm on these tractors, cyl #2 doesn't do much, and only occasionally fires. I decided to test this and tried pulling the plug wires one at a time while idling, and I found pulling #2 to have the same effect as #1. So, both cylinders seem to be in good shape. I even chugged around the yard a little, just to see it go. It didn't want to drive it much because right now the right front tire is flat. But it runs fine! 2 things I noticed. I moved the rock shaft lever up and down and nothing happened. Maybe the shafts won't turn until there is a load on them pulling them down. Or maybe it is low on hydraulic fluid. Also, how do you engage the pto? I tried turning the short lever below and to the right of the trans shifter, but nothing happened. I'm waiting for my manual to arrive so I can find out what and how much oil goes where. I know the engine takes 2 gal, so I have changed it and the filter (straight non-detergent 30w). So, I'm very pleased. Several things need tending to, but at least the engine seems perfect. Thanks for everybody's help. I'll surely be needing more as I go along. What a great resource this forum is!
