H starting problem
Jon
05-27-2003 06:51:00
I cannot routinely hand start my completely restored H. It runs well and rarely misses after pull starting. The Mag has been professionally rebuilt as well as the engine. Spark timing is right on. Shows 30 lbs compression in both cylinders, but seems to blow back through the intake valves and blows oil out of the air cleaner.Any one know a good two cylinder engine person I can talk to?
Bob
05-27-2003 12:14:57
 Re: H starting problem in reply to Jon, 05-27-2003 06:51:00
Check your valve adjustment and cam timing. You don't have enough compression.
phil
05-27-2003 08:37:57
Sounds like the cam timing could be off, intake valves are starting to open at TDC, causing blow-back (& low compression readings). Typical compression is about 75 psi.
Jon
05-27-2003 11:23:12
 Re: Re: H starting problem in reply to phil, 05-27-2003 08:37:57
Thanks to both who responded. I suspect you are right about cam timing. Would being only slightly off be partially dusguised when I pull start it, but make hand starting difficult?
phil
05-27-2003 11:39:04
 Re: Re: Re: H starting problem in reply to Jon, 05-27-2003 11:23:12
Yes, it might need pull starting to overcome the low compression. Of course, other things act that way too - pull starting can hide spark problems, mag impulse spring problems, etc.
havvey
05-27-2003 07:47:37
30 lbs does not sound right i would retest also the blowing indicates valves cracks or timing not correct
