High oil pressure on A
JDPete
05-26-2003 18:54:07
Just got my '46 A running after engine rebuild. My oil pressure is showing almost up to the H on the new JD guage. Old guage was shot. Pressure jumps up just above idle and is steady up to full throttle. Ran SAE 30 in it for about an hour and decided to drain it and put in SAE 20. Pressure is still high. Will this hurt anything? If I open it up again, how much should I turn the adjusting screw on the regulator?
Duane Larson
05-26-2003 20:29:09
 Re: High oil pressure on A in reply to JDPete, 05-26-2003 18:54:07
JDPete,
According to John Deere Field Service Bulletin 203, May 1953 your A should have oil pressure of 10-15 psi, measured at the gauge. It may be a good idea to use a gauge calibrated to 20 or 25 psi to measure the true oil pressure, then adjust to 10-15 psi. I'm not sure how the new gauges are calibrated.
