First reduction oil
Martin
05-26-2003 10:26:33
720-D, does anyone have any idea where the oil is. I changed engine oil added 1 1/2 qts of 80-90 to the fist reduction, opened the drain, dry, is there a way the oil can run into the trans or engine? Thanks Martin
C
05-26-2003 19:26:12
 Re: First reduction oil in reply to Martin, 05-26-2003 10:26:33
The first reduction drain might be plugged with some sludge. Get a stiff wire a probe and poke in the drain hole.
Clooney
05-26-2003 19:03:22
Martin, the 1st reduction cover gear area is somewhat common with the trans. Gear oil can pass from the trans to the 1st reduction cover area, & from the 1st reduction cover area to the trans, both through the PTO driven shaft bearings & the trans input shaft bearing area.
~If the 1st reduction gear oil is going into the trans but not returning you could have a low trans level or problem with the PTO driven shaft bearing area that is denying the oil path to the 1st reduction area. Not much gear oil remains in the 1st reduction cover so maybe there is some in there yet.....
