JD 430 U pto
Dan
05-25-2003 09:37:02
I have a JD 430 U. The PTO works ok but the shaft moves in and out about 1/2 inch. It turns freely when the engine is running but you can stop it with your hand easily. It seems to work ok when engaged but since there is no resistance on the shaft it is sometimes hard to shift even with an overriding clutch on the pto shaft when operating a rotary mower. I have looked over the parts book and am wondering if perhaps one of the anap rings on the shaft has moved to allow the movement. Anyone had one of these apart? Can you do anything from the back or do you have to pull the hydraulics and cover?
Henry j
05-25-2003 19:10:57
 Re: JD 430 U pto in reply to Dan, 05-25-2003 09:37:02
Dan
I think the 430 is like the 420. you just unbolt the assembly at the rear and pull it out for service etc. Hope i am not wrong on this.
